I had about a full one quarter turn of the steering wheel before any response at the front wheels. I tightened up the bolts going through the steering knuckles and axle ends and it helped a little bit. I put in a Ross thrust bearing. I don't think that did anything at all. Has anyone done anything to improve steering on this model? I have not pulled off the wheel and shaft yet, but I am wondering if the cam follower has an adjustment that might help, or just replacing the cam follower. Also been looking for a tractor with one inch spindles (I saw a YouTube in which a guy used a front end from a 1872 to strengthen his front end). I have a loader on this so I understand the need to limit the load weight to avoid excess stress on the steering parts. Thanks for any help.
This should help you out. See link: Steering
Thank you ...that was VERY helpful....Mark
What a time getting the steering wheel off...I had to make my own contraption out of pieces of steel I had around to go under the wheel and then used a flywheel puller to get it off...had to leave it soaking in a combination of trans fluid with acetone, liquid wrench, wd40 and Kroil overnight
loose the WD.
it is a Water Dispersant, shouldn't have any water on the threads.
