Jeff e-mail is on the way. Kelly
ok, now i got the oil pan. now i am worried about the spline thats on the crank shaft end. lord only knows how much work THATS gonna be. but i'll keep you posted!!! jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716 Jeff |
Jeff if you are referring to the spline on the flywheel side looks to me like it will unbolt and you can bolt on the correct three pin drive plate.
Hey, have you unbolted the pan on that ferguson engine yet? I believe that you'll be in for a big, BIG, surprise. The Cub Cadet pan won't bolt up. That's a wide-base engine and the Cub's engine is a narrow-base. Like trying to bolt a Ford oil pan on a Chevy. The PTO shaft ends are different diameters and maybe lengths also. I think you are looking at a migraine-sized headache here. Not trying to be a nay-sayer, just that some things are more work than they are worth in the end. 'Nough said.
Happy Cubbing, FFGino. |
but the 12hp kohler in my dads economy powerking is real close to being identical also other than the PK has a very deep oil pan unlike the cub oil pan! sorry, i learn more everyday from this bunch telling me to "just get out and do it!" jeff
If you put a narrow pan on this wide pan engine you might want to check here to make sure the blocks not milled out most are for a dip stick.
I see it don't have a plug for a fill tube so it might not be milled out. hard for me to bleive you bolted a narrow pan to a wide pan without mods but I have never had a pan off a MF |
From his pictures, it appears the engine originally had the 'A' style pan on it, so he wouldn't have had to change anything.
yes matt, it does have an "a" pan, like in the 301 AQS. jeff
