Old 07-11-2019, 10:47 AM
toyman's Avatar
toyman toyman is offline
Originally Posted by IH1086 View Post
When I got mine I figured out a grease gun hose works perfectly for this. It's already 1/8" NPT. I bought a 300 and 1000 PSI guage from my hydraulic shop for $65. A couple bushings and a pipe nipple for a couple bucks more and I had a "kit" just for the Cubs! I used a metal paper hole punch that I "borrowed" from my wife to make some shims out of a tin can lid. Worked awesome!
Quick update: I did get a pressure gauge, but haven't sourced the necessary fittings to adapt to the hydro unit. In the meantime, I did the same with a punch and tin can and it helped the lift, so I sourced some ~.25" washers and added 2. 1 washer was still slow and 2 lifts it well. I'll look at the grease gun hose to check the pressure, but it's working well now and only cost $.50. Thanks for all the help!
Original Member #54
Old 07-12-2019, 09:55 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
If your pressure is ok then o ring in cyl piston is leaking from one side to the other very common
