Old 02-06-2019, 10:18 PM
Steve N Mi Steve N Mi is offline
Originally Posted by timbo2 View Post
You are correct, Sam I still haven't replaced the rockshaft on that 1872, and as the OP discovered, welding the end on won't last long. whether you shear the roll pins or break the end off you're outa luck unless you get that rockshaft pulled out or back in correct position.
"as the OP discovered, welding the end on won't last long." I made a repair in a hurry and didn't consider the shaft hardness. The broken weld showed I failed to get the desired penetration. I'm confident that won't be the case now.
This is the first Winter I've plowed with this 1872 and I'm happy to have learned about the lift helper link. I imagine it will be good to have for my 54" snow thrower. The tractor (1872) I used the previous two Winters has the rock shaft all welded together.
Old 02-07-2019, 09:19 AM
timbo2's Avatar
timbo2 timbo2 is offline
Yeah anything that goes on the front is heavy and needs that bracket, I wish i knew before also, I don't think I'll ever get that rockshaft out without an industrial level press solution.
Good luck- Tim
- Tim
