Ok, ok, no rebuild just flatten the head. Since it is out do you recommend adjusting the valves? I need to replace that gasket anyway.
Yes, might as well check valve lash since you will be in there anyway. And you can clean any gunk that may be in the valve spring/tappet area.
Cheers |
Ok had the head fly cut by 6 thou and installed all new hardware. Today while trying to get the 30 min run time so I could re torque the head my pto wear button started shredding. I shut down and saw that the wear button arm was not centered and it was when I pulled the grill shell. I have side to side play in the arm where it goes through the grill shell. I have a spacer that I have no clue where it goes, but think that it takes the play out of the pto arm.
animal the side to side play on the pto actuator arm is a common problem with narrow frame tractors. The ones I use the pto 's on I have built up weld on the shaft ends and ground back to center the button. Buttons go away fast when they are not centered. That spacer looks to me like a head bolt spacer.
Too short to be a head stud spacer, and all five are installed. The funny thing is that the spacer in question will not fit the shaft, but would remove the end play if I could find a way to keep it in place on the left side of the grill looking forward.
I'd just put a couple hose clamps and washers in there...that's more or less how they came from the factory, but it seems most of them have had the clamps disappear.
Matt they came from the factory with hose clamps?
Kind of..they aren't really hose clamps but sort of look like them. I used to have a couple, but I don't know what I did with them.
