Old 12-19-2018, 07:11 AM
What model tractor is this rear blade mounted on..??
I assume that you tapped into the Hydraulic System and ran a "line set" to the back of the tractor. With that in mind, can you show how that was done..??
Old 12-19-2018, 08:39 AM
twoton twoton is offline
Roland,
I'm running this blade off the back of my 1650 Quietline with dual hydraulics. And yes, I split the front circuit to add the rear connectors.
I'll see if I can come up with some details on that when I get off work.
Old 12-19-2018, 09:27 AM
Good, people would like to see how you done that.
Old 12-19-2018, 12:32 PM
Great job on the rear blade!
Old 12-19-2018, 04:30 PM
IHCubCadet147's Avatar
Nice work!
Old 12-19-2018, 05:38 PM
Thanks guys, I appreciate the comments.
Old 12-19-2018, 07:02 PM
OK, so here goes. Sorry the picture isn’t very good. It’s all I could get.
I started out by ordering this splitter kit from xtreme;
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
I've had good luck with their products and customer service so figured that would save me some time running around. Unfortunately the kit did not work with my machine. I'm sure that xtreme would have helped me work it out but I decided to figure it out on my own.
The valve in my tractor required #6 SAE o-ring fittings which did not come with the kit. I don’t know the history of this tractor and don’t know if the valve is original or if the SAE o-ring is typical for the Quietline series.
What I used from the xtreme kit;
-The two female quick connectors
-The connector mounting bracket
-The two 1/4" hydraulic hoses with 1/4" NPTF ends (which were actually
to long and I had to have them shortened).
What I purchased locally;
-2, 6 JIC M x 6 SAE M x 6 JIC M Run Tee's, like this;
https://www.surpluscenter.com/Hydrau...6804-6-6-6.axd
-2, JIC 6M x JIC 6F Swivel 90 Elbow's, like this;
https://www.surpluscenter.com/Hydrau...9-6500-6-6.axd
-4, JIC 6F To 1/4 NPTF Swivel's, like this;
https://www.surpluscenter.com/Hydrau...9-6506-6-4.axd
I also replaced the front hard lines with 1/4" hydraulic hoses with 1/4" NPTF ends.
Old 12-19-2018, 10:43 PM
Looks like a good build, done right! It deserves more than two thumbs up.....TWO IH THUMBS UP!
Old 12-20-2018, 08:12 AM
Thanks!
