Old 12-10-2018, 08:57 AM
cooperino's Avatar
Originally Posted by heinriech View Post
Thanks for input guys! It’s probably been 6-8 months since it has started well. As far as running after it started, just about a month+ ago when I mowed last. I did put an automotive battery (smaller) but still didn’t show a noticeable difference in cranking speed. I will try that again. I also have a 16 volt automotive battery out of the race car that should kick it in the butt. Another item to note is the plugs are gapped at .043”. So not sure if that may be the issue. What do you recommend for new replacement plugs?
Cranking amps is what turns starter well or not. A battery showing 12.5 volts but has no capacity will struggle to turn an engine. If you used a car battery with nearly twice the cranking amps as a GT battery and it didnt turn as fast as it should I would start looking into other things like. Starter going bad, poor connections on battery, poor grounds, etc. The only other thing that could make an engine spin slowly would be timing, or binding in engine or other components. For instance. If your hydro were to be partially engaged during cranking that would be an additional strain. Same thing would hold true for a PTO trying to turn the belt while cranking. I would start with new plugs gaped correctly. Then I would look at wiring and battery terminals.
Old 12-10-2018, 09:50 AM
Originally Posted by Gompers View Post
Did you try both of those at the same time? Curious if one or the other made the bigger difference.
As much as (I think mostly uninformed) folks like to bag on the KT17, those things pop right off even when it's -10 out. Definitely an easier to start engine than the Mags.
One thing CCC did right in the cyclops was going to the automotive style battery. That helps a good deal, IMO.
The pug gap helped a little, the larger and doubling of the gauge of the starter wires helped noticeably more.
The KT's having battery/coil ignition, produce spark at one rpm.
What I learned is some of the aftermarket coils must have less winding's, so
need more rpm's to produce spark, or I just got a weak/cheap coil.
during summer use it works, no problems.
The original kohler coil always started in winter without problems or modifications.
Old 12-10-2018, 09:54 AM
Gompers Gompers is offline
I’m in agreement with coop here.
Regap or replace those plugs, and then take a look at the wiring. Pulling the starter is a bit of a PITA, but pulling it and cleaning it up and maybe lubing the bushing might help too.
It’s possible it’s a fuel issue, and that’s the other likely troubleshooting path, but if it’s not spinning over fast enough, it’s not gonna start.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-10-2018, 11:42 AM
johncub7172's Avatar
I'm under the impression, that to find out what the spark plug gap should be, you would try to retrieve an accurate measurement of the spark from the plug it's self using a wooden ruler, then divide that by the compression ratio. Say, if the spark was .500" and divide that by actual compression ratio.
Old 12-21-2018, 01:05 PM
heinriech heinriech is offline
Update now I have time off work and the weather is decent. Gapped the plugs to .035" and tried again. More of the same: crank crank crack, putt, crank crank crank, putt. Until it locked up. Pulled the plugs, no crank. Checked engine oil, good. Checked hydro fluid, little low but got some on my pinky. Tried to move the engine with a pry bar where the hydro driveshaft comes off the back of the motor and will not move. should I be able to roll the motor from here with a pry bar? The tractor does roll forward and backward 1-2 feet.
How far can I push this thing to get it up to the front garage where I can really dig into it?
Thanks for all the help!
Old 12-21-2018, 02:35 PM
If you go nice and slow, you will have no problems.
Old 12-21-2018, 03:10 PM
Roland should I be able to roll the motor with a pry bar on the rag joint at the rear of the motor? With the plugs out of the motor.
Old 12-21-2018, 03:20 PM
You should unless the starter is stuck on the flywheel ring gear.
Old 12-21-2018, 03:36 PM
I can roll my M-20 over by hand, at the Flex Disc Joint. Unless, like Lew said.
Old 12-21-2018, 04:32 PM
Should absolutely be able to roll it over by hand, especially with the plugs out.
Those symptoms still sound to me like it's not spinning fast enough.
Also possible your starter has soiled itself.
