Old 11-11-2018, 12:57 PM
RLause's Avatar
RLause RLause is offline
The cam gears are plastic.
And as far as them dropping into the crank case, it happens but it was not as frequent as some think.
g.
If the governor gear shaft is pinned as per the service bulletin the gears don't fall off.
Richard
Old 11-11-2018, 02:04 PM
cooperino's Avatar
Originally Posted by twoton View Post
Looks like a money pit.
Lol.. aren't they all tho?
Old 11-11-2018, 02:12 PM
SS5150's Avatar
SS5150 SS5150 is offline
That's a parts machine
No more than $100
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 11-11-2018, 02:33 PM
cooperino's Avatar
No more than $100
So, you have been to this guys house and saw it huh?
Old 11-11-2018, 03:45 PM
It is worth whatever you are willing to give for it. I would want to hear and see it run before I put $300 out for it, if he claims it to be a runner, otherwise, my personal limit would be $200. I would look at it carefully, to see if all of the parts are there. If not, then how many are missing and what would it cost to replace them. For example, the side panels are roughly $40 to $60 to replace them. Also, look at the front nose for cracks where it is bolted to the frame or cracks in the hood/hood hinge. I see those too often on the 82 series tractors. This isn't your first tractor, so look at the normal things that you look at, knowing that some wear and tear on the machine is to be expected, like slop in the steering, etc. Good luck on getting the tractor.
Old 11-11-2018, 04:11 PM
And FWIW:
When you pin the plug holding the gear shaft into the block,
make sure you leave enough length to pull the roll pin out, if the need arises.
OR drill the hole deep enough so the pin can be driven into the
shaft plug, to allow it to clear the block so it can be removed.
Old 11-11-2018, 06:22 PM
What he said...
For what your gonna put in to it I will sell you mine.
Up to 530 and counting...
Old 11-11-2018, 06:27 PM
twoton twoton is offline
What he said...
Dual wheel weights!
Old 11-11-2018, 06:36 PM
Gompers Gompers is offline
You don't hear about the thousands that run ok, just the ones that don't.
The series one's had oiling problems as stated.
And for sure, not worth fixing.
Cam gear is metal. Oil pump gear is plastic. Governor gear is plastic.
I haven't heard much about the KTs dropping gears, but I'm sure they did if the mags did. Same castings.
I wouldn't be worried about whatever is in it if it runs. If the series 1 survived this long, it's probably ok. If it's a series II, it's more than likely a replacement engine. Of the half dozen 782s and 682s I've bought/sold, only one has had the original series 1 in it (and it ran great). All of them would have had a series 1 from the factory.
Others have covered the major 82 series bases. They are great tractors, and parts are readily available. They made a ton of this style (it's the same tractor, more or less, as a 1711/12, 1811/12 as well).
In the shape that's in, I'd buy it as a parts tractor. There is a LOT of work there.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 11-11-2018, 06:40 PM
Dual wheel weights!
and one set of 18lb wheel horse ones too.
