Thank you Roland. It Seems like I posted with the invisible ink option , but yes, what WE said.
I took it to mean the starter continues to crank after the key is released to "run" position. |
Arrrgh// if it is "spinning" it is "cranking" whether the ignition fires or not.
Oh,
it's all so confusing, ![]() I don't know if I'm winding my arse or 'cratching my watch. Lets see, da little gear makes da big gear go round and round and da piston go up an down butt da sparky don spark sumtimes, till he jiggle the do-ma-hickey. Me thinks dat be da problim.
Maybe this will clear things up....
This is correct.
![]() ![]() ![]() '76 1200 Dad bought '75 1200 "Twinsie" per my daughter |
Incorrect, starter disengages
Again, sorry for the confusion. I've been working a bunch and in the process of moving my 86 yr old Dad in with us.
It'll be this weekend before I'll be able to get to it.
You need to have 12 V to the primary of the coil while you're cranking. Sounds like you do not.
Get a new switch... and you should be good to go.
