Old 10-10-2018, 01:19 AM
colt54 colt54 is offline
carb is clean. the leak is on the air filter in the pic. The gas tank is clean and nothing on the screen. Gas line is new and so is the inline gas filter. IM going to play with the float a bit.
Old 10-10-2018, 10:25 AM
Float is probably out of adjustment for the leak issue. Your fuel delivery while using is probably due to your inline filter. Take it off and replace it with the sediment bowl that was originally on the tractor.
Old 10-11-2018, 08:52 PM
jbrewer's Avatar
jbrewer jbrewer is offline
^^^ Betcha those are your two problems :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-15-2018, 01:26 PM
Ok i took a carb off a good running tractor and still have the same issue. Not sure what the problem is.
Old 10-15-2018, 01:41 PM
Chad126's Avatar
Chad126 Chad126 is offline
Are you sure that is 100% gas in the air filter? From the picture it looks like oil on the green filter. Is it smoking when you have it running?
Also, I'd put a clean filter on it to make sure it was breathing in enough air when moving at WOT.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 10-15-2018, 01:59 PM
Did you replace your fuel filter with the sediment bowl? Do this and report back. If you can't find one locally, they are on Amazon for like $12.
Old 10-31-2018, 03:40 PM
Chad126's Avatar
So what is the diagnosis? Don't leave us hanging man! We like to hear back on what was wrong
Old 10-31-2018, 05:43 PM
Merk Merk is offline
I have a grass catcher system that has a separate engine. I had the same problem the original poster had with my bagger engine. I picked up leaves after the sun went down and saw sparks jumping from the metal part of the sparkplug to the sparkplug boot. Change the sparkplug and the problem was solved.
Not sure if this is your problem...….worth checking
Project Uncle Dick
Cub Cadet 70
Old 11-25-2018, 12:23 PM
After playing with it for day's. New coil points and condenser fixed my problem. purrs like a kitten under a load again.
Old 11-25-2018, 03:53 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Glad you have your 129 running like a happy feline! It was probably just the condenser like one poster, ol' George, suspected earlier.
Plow blade
#2 Cart
QA36 snowthower
