Old 10-07-2018, 09:16 PM
cooperino's Avatar
One final thought on this.
I think this has been a good constructive conversation and would like to bow out before it turns for the worse. So my final thought is this. I'm guessing the engineer that designed this has more knowledge of how this should work than any of us here. I doubt that the holes were meant to just get get clogged up with grass and do nothing. I also looked at some spindles from some othe high vac decks and saw that there were openings where they mounted to the decks also. There's definitely some reason for this design and I think it has everything to do with vacuum
Old 10-08-2018, 08:39 AM
dale c. dale c. is offline
all of the ones I have mowed with do push grass up through those holes [especially dry grass] that's why the top of the deck is always covered with grass . if the pulley gaurds are in place they're usually plugged solid from not being cleaned out
Old 10-08-2018, 08:53 AM
cooperino's Avatar
Ok. so air is pushing up from there. Do you use with mulching cover on or side discharge open? I am actually reading one of the patents right now for this design.. Its a long read tho lol.
Hmmmmmm...... so air isn't sucked in from the top through those holes. Who would have thought that?
Old 10-08-2018, 08:55 AM
bugeye bugeye is offline
How about someone who has this type of deck hold a piece of paper near the opening while running the mower. The deflection of the paper will indicate air flow direction.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 10-08-2018, 09:01 AM
cooperino's Avatar
Seems that is the case in this situation.. I never mulched with mine and those vents stayed clear. With the mulching cover in place I assume there would have to be air pushing out. I didnt think of the mulching cover until I started looking at the patent docs this morning.
Jon, Perhaps I was thinking of this backwards. Do you think with a mulching cover in place that those vents may be necessary to create the vacuum? In other words, If the deck was sealed shut would it create as much flow as it would with out some sort of vent like the ones in question? Does the deck work as efficiently once those holes become plugged up?
