I wanted more info on the meaning of the numbers etched on the Mikuni carb because I was trying to figure out if the carb was original to the engine.
I believe I have stumbled on to a clue! The engine CODE : 98030611 means the engine was manufactured 03/06/1998. Correct? The B&S repair manual says (on the carb index, page 75) the Mikuni carbs were used on this engine (303447) before 08/01/1995 and they used a Nikki carb for my engine starting 08/01/1995. Either they used a left over Mikuni carb body (explains same #'s as on Nikki carbs) or someone replaced the carb (doesn't explain the Nikki #'s on the side). If I knew what the #'s on the carb represented (date code) then I could confirm either way. |
Side note,
I contacted B&S. They replied, B&S didn't use Mikuni carbs on there engines. They were no help at all! |
![]() Quote:
That is my suggest. It is your tractor, your time, your money, your decision.
My 303447 has a spec code of 97111111. Let me go snap a few pics for ya.
IH, the over flow tube is only 3"-4" long (or 10" depending on who I'm talking to)
![]() Here are some pics of the carb. The numbers on the side are: 6100 22-121 808069 94(looks like a 4)B DSCN4135.jpg DSCN4138.jpg DSCN4140.jpg DSCN4142.jpg
Hey, thanks OAK!
That looks like mine. I have seen no evidence of any other "WORK" done on the machine so I'm guessing it was a left over carb shell that was used. Also only has 362 hours and I'm confident that is correct. No wear in usual places. |
Based on the numbers you posted "303447, 1279-E1" this is what you are supposed to have on that engine.
https://www.jackssmallengines.com/ja...303447-1279-e1 https://www.jackssmallengines.com/ja...-e1/carburetor
