Old 11-02-2018, 12:01 PM
On an older style tractor, the neutral return is about 1/4" farther back, so if you're swapping a newer pump onto an older tractor or vice versa the neutral return linkage must be adjusted.
I don't think so. The only difference between Ported and Non-Ported pumps are two fittings on the pump.
Old 11-02-2018, 12:35 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
The year is what matters. The neutral return is in the same place on a ported vs nonported if they're the same year.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 11-02-2018, 01:00 PM
OK, show me where in the Manuals it says that.
Old 11-02-2018, 02:36 PM
dodge trucker dodge trucker is offline
Interested in this thread as I have a 129 that is pretty clean and runs along with an engine less 1650 that I plan to rob the ported pump and hydraulic lift from to transplant onto the 129.. when I got the 129 and checked it out to see if it ran, it lurched heavily forward and I couldn't get it to respond to the hydro control, so in order to get it running without fighting against the starter generator, I took the driveshaft out. I haven't had a chance to get back to the 129 and actually try to figure it out yet (it's down the list a bit) but regardless of what it would take to get the lurch gone I want the hydraulic lift on it anyway. So I'm watching this to see what fun I might be in for when I finally do get to spend some time with the 129.
Old 11-02-2018, 03:41 PM
Mudrig150's Avatar
Why would it say that in the manual? It's just something I figured out.
Old 11-02-2018, 04:25 PM
cooperino's Avatar
I think what Roland Is saying.. and what I would also like to see is the "year break" where something was changed. Like show us a manual with one then a later manual with the other. This "if true" would be good info to have.
Old 11-02-2018, 04:58 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Mudrig150....the hydro linkage is the same among all of the years and models of the Quietline series. THE only difference is the pedal return spring...later models used a longer spring and in a different area. Linkage adjustments are unique to each tractor and that is probably what you are experiencing. Ported and non ported pumps do make any difference in terms of linkages!
Queen Of The Quietlines!
