That's the kind of talk that will get you
I just said I didn't need another one, I never said I didn't want another one.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Very Nice!! The #4 carts seem kind of rare.. at least around here!
![]() I'm guessing a third party was making the #4 carts for IH? The only reason i'm asking is that I have a Gravely cart that was purchased new from Gravely in 1987.. It is IDENTICAL to the IH cart with the exception of the tongue. The Gravely cart has flat channel tongue where it looks like the IH tongue is round? Tires, axles, body and tailgate are all exactly the same.. even has the same corner braces on top edge of the body.. Anybody that knows or could shed some knowledge on the MFG?
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
This may be my problem.
I have a new driveshaft from Jeff that I'm going to put in.
I also noticed the flywheel screen is missing. Is that a problem?
If you want flies to get in no, grass is a bigger problem, now is the time to get one.
Ok, I'll get one.
I got my driveshaft in and tried to cut some grass and noticed two more problems.
First is when you pull the drive lever back to neutral, the hydro pump moves a little. I don't think it is the whole transmission, just the pump. The tractor seems to drive fine. I have to pull the fenders off tomorrow and see what's loose. Has anyone ever seen this before? And the second thing, I noticed a noise coming from the front, I think it's the PTO, because I only heard it when it was engaged. It seemed to work fine for the 5 minutes I used it. Any ideas what could be causing this?
