Old 06-05-2018, 03:34 PM
Originally Posted by bllwnkl View Post
Thanks, I appreciate it. My spark plug looks normal to me.
I would richen the carb just a hair and throw a new plug in it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-05-2018, 03:36 PM
cooperino's Avatar
Not sure how long you ran it in the engine. Amount of time run and at what RPM would make a difference. I would call that going towards the lean side just a little.. Is this a twin? if so how does the other look in comparison?
Old 06-05-2018, 05:22 PM
Here's the plug. Without cleaning it, the gap is .030.
Attachment 93335
You are on the lean side. I agree with Tim, give it some more fuel.
I would also be checking the air filter and filter housing. Either the engine is burning a bit of oil, or it is getting a bit of dirty air. Looks to me like it's getting dirty air. How loose is the throttle shaft? A loose throttle shaft will make it run lean, and suck in dirty air.
Old 06-05-2018, 06:54 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Generally better to err on the side of rich....!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-05-2018, 08:17 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
You must not have seen post #7. It's a new carburetor. It now has a new shut off valve, filter, fuel line, air filter and pre-filter, and spark plug. That plug was in it with a carburetor with a worn throttle shaft and the old air filter.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 06-05-2018, 08:25 PM
cooperino's Avatar
Yup, put a new plug in it. 3-4 hours of regular use and have another look
Old 06-05-2018, 08:27 PM
bllwnkl's Avatar
I just put a new plug in it. This is a 1250 with a Kohler K-301 AQS engine.
Randy
Old 06-05-2018, 08:29 PM
jbrewer's Avatar
We'll look for a new picture in about a week :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 06-05-2018, 08:34 PM
bllwnkl's Avatar
Yes, I need to mow but we had a downpour today. Hope it dries off enough tomorrow. It takes me two hours to mow. We'll see.
Randy
Old 06-05-2018, 09:03 PM
I did miss that.
I bet that's why the plug looks like that then....
