Old 05-19-2018, 06:45 PM
Valleyvfdfirefighter Valleyvfdfirefighter is offline
Originally Posted by jerkin View Post
Did you check the spark while it was hot or after it had cooled down? Coil going out will sometimes work when it's cold then quit after it heats up. Maybe it is the unburned fuel you are hearing and causing the occasional white smoke? Smell any gas in your oil? That would be a sure sign. Just something else to check but I'd probably still yank the engine and clean it, just did it to my 1864, not a bad job at all.
Yes sir,
It had spark both cold and up to the point that it shut off. Would even spark as I was trying to restart it. I did this test by running my inline spark tester on it as I was mowing. Did it for both cylinders.
Appreciate all the feedback from everyone I'm hopefully going to chuck it up to crappy fuel the neighbor gave me as I was mowing his yard.
Tags
2082, boling, carburator, fuel
