Old 04-01-2018, 01:00 AM
Those look really great! Certainly give it more of "tractor" look and more grip on the turf. I agree with Jonathan about painting them with just the rims, but I totally understand why a person might not, as I have run short on time and said, "Oh, I'll paint them later....". Its just easier to do when they are not mounted. Miss Deltacub and others have a really great suggestion on loading them up. No that you have some extra grip, might as well make the most of it!! Glad your "ship" finally came in......
Old 04-01-2018, 07:12 AM
Looks great Daniel. I use Jon's method and squirt some dish soap around the bead and then bounce them around like a basketball. As he said too, pump them up to 30psi and they should pop.
Old 04-01-2018, 09:30 AM
Congrats on the Firestone's Daniel.
I hope that the picture you have with the tires mounted, with the one on the pail, the tire on the floor isn't mounted backwards.
Oh, and a third on what they said about seating the bead.
It’s an optical illusion. I checked myself about 10 times when mounting to make sure I had the direction correct.
Old 04-01-2018, 10:10 AM
Stick tubes in 'em and fill 'em with W/S washer fluid. About 6 gal per tire is what mine took, raised the weight up to about 77lbs each. on my 10.50's
I built a standpipe from 4" ABS pipe with an outlet at the bottom and a valve stem at the top. Takes about 4psi to shoot 'em full. just be sure to capture the valve stem while filling to avoid loosing it inside the rim while filling.
Takes about 5 minutes per tire, piece of cake.
Wal -mart has the fluid for about $1.80/gal when on sale
Old 04-01-2018, 12:03 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Looks really good.
Maybe a thin coat of some clear to keep the rims from re-rusting quite so quickly (or at least a good coat of wax on them).
Great looking cub!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-02-2018, 02:35 PM
johncub7172's Avatar
Welcome to the club! I have yet to try mine out on my 1450. Have to make the engine all pretty first ya know
Old 04-04-2018, 05:00 PM
I took the tires to a local tire shop to have them seated. The guy said that he had a tire explode once while seating it between his legs (to which I responded that's why I'm letting you do it!). He put them in a cage; then they were seated and aired up for a very Lew price. What it really did was save me peace of mind.
Old 04-04-2018, 06:12 PM
Smart move Grasshopper.
Old 04-04-2018, 06:34 PM
jbrewer's Avatar
Lew's gotta eat too!
I've seated car tires and it's never been my favorite thing. I'd be glad to let someone else seat the beads if it was affordable!
Good call...
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-05-2018, 09:46 PM
Mounted the wheels to the 147 today. I like that I have an alternate set of wheels to throw on in the winter, keeping the turfs with the chains and weights. Having grown up with that tread pattern on Dad's 125 it is great to make the impression again but this time in my lawn. I'm super impressed with the way it looks now. Originally Dad bought the tires he has because the turfs he had wouldn't climb the hill that is his front yard.
