What you need is a wing screw- a screw with a head on it like a wing nut. You may be able to find something to work at the hardware store. I use a fender washer on the screw to cover the big slot that is in the sidepanel.
The holes are threaded 1/4NC20. Another alternative, you can run a 1" long 1/4" bolt through the holes from the inside of the dash tower (probably have to move the gas tank), tighten them down, and they will be like a stud on the outside. Then you can use a regular wingnut with a washer, or even a regular nut if need be.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Thanks for all the tips on attaching it, I'll get it fingered out soon.
