Thread Tools
Display Modes
I'm going to use a bolt, no worries about the spring breaking or falling off and the belt will be almost guaranteed to not slip.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains |
Just remember, there is no slip clutch on that tiller, or shear pin. You want one of the two belts to slip if you hit something. It happens. I've had a garden in the same spot for 4 years this year. Every year I catch something in the tiller that stalls it. Rock, brick, what's left of a metal post. Just making sure you know it needs to give somewhere.
I usually slip the small belt on the tiller. Lots of torque applied there, easiest place to slip. |
Also noticed the mule drive must have been ridding on the front axle for a long time and started putting groves into... prior owner abused the poor tractor.
![]() Quote:
Don't miss post 12. We posted at the same time. |
Normally yes the smaller belt slips. However, I hit a root last year and threw the long belt.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Tiller is working great!
Just FYI, the tiller operators manual actually says to do exactly what you just did. Replace the spring with another tensioner bolt and some washers through the big hole where the spring used to be if that's the mule drive you are using.
Looking good, hope to get mine out this weekend for the 1st time.
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus ![]() |
