Old 02-28-2018, 11:46 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I can make the rear coupler with a couple set screws to take out some slop. It's not a perfect fix ( but a good one ) and can save a worn pump shaft.
I have used Jeff's coupler on a worn pump shaft.. it works great.. highly recommended if your shaft is worn at all.. much better part than original
Jay
Proud owner of the following:
Old 03-01-2018, 03:54 PM
joeyxx2590's Avatar
joeyxx2590 joeyxx2590 is offline
So, I got the driveshaft out today. The play/slop I was feeling is the universal joint being worn out. With a 1/4" bolt in the transmission shaft, there is a little wobble room nothing too crazy. The ujoint was snug on there so I do not think it was wearing the hole out. There was a regular roll pin in there and not a spirol pin.
