Old 02-12-2018, 10:19 AM
athomas's Avatar
athomas athomas is offline
I had a bad plug wire once that would let the engine idle and run up to about half throttle then start cutting out like it was not getting fuel ,should run a solid core plug wire on these for best results,change wire and see if it helps !
Old 02-12-2018, 12:15 PM
john hall's Avatar
Originally Posted by GaryC View Post
John, when you're suggesting the engine is waiting for the carb bowl to fill up again . . . is that in relation to the single incidence of "surging" I mentioned, or the fact that it's all of a sudden falling off and dying (four times now).
Thanks,
Gary
I was referencing the sudden shutdown. If it is a fuel flow problem, assuming you run at the same speed each time, you should darn near be able to set your watch by how long it runs---just long enough to empty the fuel bowl. The way I check that is to remove the line at the carb, open the shutoff and see how fast it flows, needs to be more than a dribble--obvious precautions should be taken catching and disposing of the fuel.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
