![]() Quote:
Why spend $165 as Oak's post stated when the old voltage regulator system works ????? Maybe I'm not understanding this ![]() ![]() ![]() My biggest concern is how well the Clover solid state system holds up under engine vibrations and wet conditions.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
That Clover DR-110 looked very interesting to me. It looked like a quality built product. It also looked like it would work on our Cub Cadets quite well. It had me up until I seen the price.
Thanks everyone for the input!
![]() Quote:
Mechanical regulators and generators were a little before my time ![]() |
![]() Quote:
But not to worry, I'd bet that as we speak, the Chinese are already duplicating them and they will be appearing soon at an eBay near you. (for $12.95 and free shipping) |
That solid state regulator is nothing new.
Been something like that produced 50 years ago. Back when we went to alternators on vehicles from generator systems, approximately in 1963. the Alternator changed the produced AC current, to DC in the alternator with usually a 6 diode rectifier. Then externally they had the familiar regulator box that looked much the same for generators or alternators ,(like cub cadet looked) Late 60's early 70's, Ford ( Motorcraft) produced a solid state regulator replacement "kit" ( No internal coils or points to arc, wear out or adjust.) It was a direct replacement, fitting the old regulator bolt mounting pattern. it did come with a short plug-in adapter harness. The regulator cover was only maybe 1" high, versus the near 4" of a conventional coil/points mechanical regulator. in the early 70's, most went to internal voltage regulators. So, regulating DC current with a solid state regulator is nothing new whether it is a rectified alternator producing DC or a DC generator/starter like cub cadet, and many others. Apologies to all who already know this. |
![]() Quote:
![]() I’m not going to go buy a bunch of them and start replacing old ones but I might try one on my Fcub.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
There are a bunch of different ones out there. I think the clover ones are on the higher end. Just google solid state dynamo regulator. Some just regulate voltage and not current. Some do both. Looks like you could have something that would work on a Cub for less than $100, but might not look factory or be adjustable like the fancy Clover one.
George, correct me if I’m wrong, but don’t alternator regulators just regulate voltage and not current since alternators are basically self regulating when it comes to current?
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
![]() Quote:
The regulator(s) you are referring to are easily available and actually cheap. Now you've got me thinking about doing some electrical experimenting. https://www.amazon.com/Standard-Moto...=1516111374216 |
![]() Quote:
We used to build alternators but not install the rect. and build a 110V.AC output. Some Lincoln's had a 110V rear window defogger, so they actually had 2 alternators mounted on the engine. I don't remember if they went into production but we built a run of prototypes. They had to somehow control the voltage, as it is linear to rpm's. |
![]() Quote:
