Old 12-06-2017, 09:05 AM
spudder spudder is offline
Rescue 11.....I didn't mean to imply that NO ONE here could help the OP with his inquiry. I know for a fact that you are very qualified to supply the information needed, and I hope you do.
I referred him to MTF just because I am familiar with their hydraulics forum. My intention was to help provide another source of information. I certainly didn't intend to pee in your Wheaties!
I bought a 1864, it's just grown from there. The Cubs have replaced old Chevys as my hobby/passion. The only car I have left is a '67 Chevelle wagon.
Seems like a good trade off. I can put five Cubs where one car sat and there are no titles or license to fool with!
Old 12-06-2017, 12:06 PM
Terry C's Avatar
Terry C Terry C is offline
I don’t think he took it that way, at least it didn’t sound like that to me.
If you want to offend rescue11, you are going to have to try harder.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-06-2017, 09:04 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Terry, what is the bore of your log splitter? You say your log splitter is a priority over the sickle mower, so what is your log splitter powered by at the present time? Or is it To Be Built?
1- 1200 in pieces
1- 1864 in pieces
Old 12-06-2017, 09:13 PM
Terry C's Avatar
Will be building it. Figured the splitter would require the most pressure so that’s why I was basing the pump on that. Splitter is not a priority so if one pump will not do both then I would pick the sickle mower as what I need the most.
Terry
3225
Old 12-06-2017, 10:00 PM
Rescue11's Avatar
My only thought so far is that the log splitter would drive the train on the pump choice
Misinterpreted this part of your earlier post.
It just depends, if you're wanting a pump that will run anything you throw at it, you're looking at higher GPM, along with a suggested PSI north of 2K. 13 gallons a minute would run your log splitter fairly well, along with anything else you could think of, IE your sickle mower, a shredder, or something that I've thought about... Hydraulic drive post hole digger. You have enough horse power to run one that big, but the biggest issue with having that kind of flow is oil Cooling. General rule of thumb for cooling is one gallon of storage per 1 gallon flow. So you could probably get by with a 10 gallon tank. The other option would be to install a oil cooler with an electric fan. Variables such as run time and load go into that as well, meaning if you weren't planning to mow 60 Acres of Alfalfa in a day you can probably get by with a smaller Reservoir. Or if you weren't figuring on splitting 60 cords of wood a day, you can probably go with the smaller Reservoir.
13 gallons a minute is basically what I have figured up for my hydraulic drive PTO that will allow me to transfer the power and torque that I want. I'm thinking this is overkill for your application, but again it really depends on how much time you're planning on running this setup
Really would like to know what size cylinder you are running on the log splitter
(Edit) If you used a 4.5" x 24" cylinder your cycle time (without a load on the cylinder) would be around 14 seconds. If you had a 2,500 psi relief, you would be looking at approximately 20 ton worth of splitting force.
1- 1200 in pieces
1- 1864 in pieces
Old 12-06-2017, 10:09 PM
Terry C's Avatar
It just depends, if you're wanting a pump that will run anything you throw at it, you're looking at higher GPM, along with a suggested PSI of 2K. 13 gallons a minute would run your log splitter fairly well, along with anything else you could think of, IE your sickle mower, a shredder, or something that I've thought about... Hydraulic drive post hole digger. the biggest issue with having that kind of flow is not your horsepower, it's oil Cooling. General rule of thumb is one gallon of storage per 1 gallon flow. That's a big Reservoir. Variables such as run time and load go into that as well, meaning if you weren't planning to mow 60 Acres of Alfalfa in a day you can probably get by with a smaller Reservoir. Or if you weren't figuring on splitting 60 cords of wood a day, you can probably go with the smaller Reservoir.
That sounds like a place to start. Mine would be limited use. I don’t heat with wood, just a fireplace. Sickle mower for the sides of my lane. If it took 15 min to mow the lane I would be surprised. Thanks for the information
Terry
3225
Old 12-06-2017, 10:42 PM
Rescue11's Avatar
pm sent, looking forward to your build!
1- 1200 in pieces
1- 1864 in pieces
Old 12-07-2017, 08:08 AM
Looks like this is gonna be a fun build. We're gonna need lots of pics too Terry.
Old 12-15-2017, 06:35 AM
twoton twoton is offline
......looking forward to your build!
X 2
