Old 11-06-2017, 09:09 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Awesome build! Should be fun to operate too!
Queen Of The Quietlines!
Old 11-07-2017, 05:23 AM
Nice job!
Old 11-07-2017, 08:59 AM
Nice work!
You don't need a master relief valve. They blower is belt driven and so is the pump. I'd only be concerned if it was direct drive. You will either slip the belt, or break it before you blow a hose or pump/motor housing.
Old 11-07-2017, 01:05 PM
Dirty Steve's Avatar
To the man on that! I like it!!!
Old 11-07-2017, 01:15 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Thanks for the kind words guys. I do have a float function on the kwik-way if I need. The motor is from norther tool. By-directional, pump or motor.The releif valve I was going back and forth on. I'd rather not have it since it would be another hose back to the tank to deal with. The fact Im running a case drain does give the oil a place to go in the event of a lock up, but I agree the belt will slip before any thing else.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 11-07-2017, 03:15 PM
bugeye bugeye is offline
Looks to be the perfect size for the tractor. Are there shear bolts on the augers? Impressive adaption.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 11-07-2017, 03:31 PM
Terry C's Avatar
Terry C Terry C is offline
Not to derail but this project makes me realize I could power my rearmount Haban sickle with one of those! Thanks for the inspiration!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-07-2017, 04:18 PM
Terry, why not mount it like Ken did on a FEL, then you could use it to trim the hedges.
Old 11-07-2017, 04:23 PM
Terry C's Avatar
You are an “outside the box” kind of thinker aren’t you Todd!
Terry
3225
Old 11-07-2017, 05:14 PM
ken6x6's Avatar
Hydraulics open all kinds of doors. A hydraulic sickle bar would be pretty cool.
I also discovered the blower is made by Agri-fab, this same blower is also used by John deere and Cub Cadet. Just rebranded, and parts are still available.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
