Old 06-20-2010, 11:51 AM
I use brake cleaner because it evaporates completely with no residue. If you wipe the inside of the case out before the brake cleaner dries, you'll have a perfectly clean surface. Degreaser doesn't evaporate, and most are water-based, and you don't want water in there...that's what caused all those globs of crap.
Old 06-20-2010, 11:54 AM
jrob33 jrob33 is offline
All right Matt, thanks. I'll go get some brake cleaner. I'll have some after pics. It'll be a few days though, working swing shifts.
J Rob
Old 06-20-2010, 01:16 PM
Derek E Hopper's Avatar
Derek E Hopper Derek E Hopper is offline
Smile
Sweet Project !!! !!! !!!
Old 06-20-2010, 03:55 PM
Default Rearend/axles/tubes
That's fairly typical sludge. You can wipe out all of the chunks with rags, and then do the final cleaning with brake cleaner. Considering how horrible that is, I'd be tempted to remove the rearend and remove the axles and axle tubes, as there's probably a quart and a half of nasty Hytran trapped in the axle housings. You'll need new gaskets for the axle tubes and new axle seals, but I think it'd be worth it, and you're halfway there already.
Matt (and anyone else),
So what all is involved in removing the rearend, axles/tubes? Is that described in the Service Manual and any helpful hints would be appreciated.
JRob
