Old 09-29-2010, 06:18 PM
Get Harbor Freight's O-ring assortment. For the $10 or so it cost I have fixed a lot of cylinders and control valves.
Good tip Matt! Do they use a seal of any kind or just o-rings? I've got to rebuild my control valve it's starting to drip any tips?
Thanks!
Old 09-29-2010, 09:19 PM
The cylinders on my loader (Kwik-Way) had a mix of crude lip seals and O-rings, and the rebuild kits I got were missing parts and had the wrong size O-rings for a few of them, so I wound up re-using the lip seals and replacing just the O-rings. It didn't completely eliminate the leaks on mine, as the rods are kind of screwed up on several of my cylinders, but now it's an occasional drip instead of a squirt every time the cylinder is actuated. Every valve I have disassembled has contained only O-rings. As for tips, clean the outside before disassembly, and clean and re-lube all of the internals before reassembly. The O-rings get pretty bad in the control valves. I have never taken one apart that didn't need all of the O-rings replaced.
Old 10-02-2010, 12:16 AM
klejeune's Avatar
klejeune klejeune is offline
Sorry guys, I haven't been around the Cub forums much since about January of this year.
I got my Danco decals from Scott Urschel. The only way I know to contact him is by email: cubconnection@aol.com I believe is the address.
Good luck, I'm always looking forward to seeing rebuilt Danco loaders.
Keith
I like pie
