Old 07-10-2017, 11:02 AM
Originally Posted by Mr Bob View Post
J-Mech, Thanks for your input. When I first pulled the oil pan and checked the tab on the cam it was bent inward. This is an early engine and I don't believe the tab is hardened. I bent the tab back to specs. and as I rolled the engine over by hand,the exhaust valve opened slightly before firing mark. This was with the head off and no compression. After I put oil pan and head back on engine, it started right up and ran well. Shut it off to try it again and it would not roll past compression build up. I really believe that the tab has metal fatigue and when it hit compression the second start, the tab had bent back out of position. I guess a sticky valve is possible so I will remove the head and check the valve operation. I am not sure this would show anything but I don't have tools to remove the valve. Thanks again for your help and have a great day.
Bob
Bob, I don't know your abilities but a valve can be removed/installed with 2 big screwdrivers, a daub of grease,a small pencil magnet,and some patience.
But if you don't feel comfortable, I respect that.
Old 07-10-2017, 09:45 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
George, back in the late 50's and 60's I was Drag Racing at the local tracks. I ran a Chevy with a 283 engine and I tore it completely down in the fall and rebuilt the engine for years. Never blew an engine while racing. Today at 80 years of age, I am a little hesitant on doing tedious things like removing a valve. I was wondering if the exhaust valve was sticking,would there be a miss in the engine or a pop in the muffler? Once the engine starts it runs fine. Thanks for your input and have a great day.
Bob
