Old 06-03-2017, 06:19 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Originally Posted by TIMCRUTCHER View Post
Or why not fix it right instead of "jerry rigging".
Not everyone's tractors are trailer/garage queens. Some people actually use these things to do work. Down time is not always an option.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-03-2017, 06:58 PM
I see no reason to knock yerself out if you come up with something that works just as well or maybe even better.
My fix for the same thing was a piece of used rubber fuel hose zip tied on each end of the spring. Has worked fine for about three years.
Cost was for two zip ties at the bulk price you pay in a 100 count bag.
Old 06-03-2017, 08:43 PM
RLause's Avatar
RLause RLause is offline
I think IH should have done this from the beginning. Then as the pin wears there is never any play. Kohler does the same thing on some of their carburetors to eliminate play in the linkage.
Richard
Old 06-04-2017, 06:00 PM
Old 06-04-2017, 06:09 PM
jimbob200521's Avatar
Two polarizing sides to this issue. Either "fix it back to stock/right" or "there may be a better way/do what it takes to get the job done". I for one am all in for finding a better way. Heck, I had a Cub once (emphases on "had") that the previous owner had jerry rigged a way to eliminated the springs in the trunion. Made the hydro much more, shall we say, sensitive, but it eliminated the potential wear problem associated the springs. So there's a give and take here.
-Ryan
Old 06-04-2017, 07:12 PM
Another way to look at it..........................
Everybody's trunion gets worn, sooner or later. Most people seem to want to fix it by the book. Spend money, time and energy and the end result, they come up with something that will fail, sooner or later.
Why not try something different instead of being a slave to the book? It's only a garden tractor. Not a moon rocket.
