Old 06-02-2017, 10:58 AM
x.bhamcb x.bhamcb is offline
I don't have much experience with these, so this may be a crazy idea. Is it possible that the heat from the failed PTO damaged the crank bearing on that side? If that is the case it may be a fairly easy fix.
Old 06-02-2017, 11:34 AM
There is no bearing .
Ryan,
Maybe you just overheated the engine letting it idle for so long.
Old 06-02-2017, 12:18 PM
Even if it did, which is very unlikely, that IS NOT even close to an easy fix. That's major surgery.
Ryan, pull that new PTO off and see if the problem goes away.
Old 06-02-2017, 12:23 PM
jimbob200521's Avatar
Originally Posted by PACubCadet View Post
Seems like your luck is about equivalent to mine half the time. Sorry to hear that your motor took a long vacation, but on the bright side you have a brand new PTO?
New PTO is the bright side but the brighter side will be once I'm satisfied it didn't get damaged!
Do a little more checking before you give it up for "done blowed up" as they say in nascar.
It is possible the new PTO is amiss somehow???
oil/dipstick on an engine @ operating temp, is nothing you want to touch.
I agree oil at operating temp is a no no but trust me when I say it was much much hotter than it should have been. Let's just say I'm surprised the plastic air filter housing didn't get disfigured from the heat
Originally Posted by Berwil View Post
Agreed. I just had pto issues on my 1450, whole tractor started shaking, I slowed the engine down and it died, went to crank and it was locked up. Since you just worked on the pto, I'd at least pull it off and see if it spins.
Bill
I'm with George. It's worth a try removing the PTO first
I do plan on double checking the PTO when I do the swap since I want to eliminate that but I'm personally pretty sure it's not the cause/issue. I can spin the pulley on the PTO by hand now but I know there's another bearing to check so I will do my checks before I write that off completely
What they said.
But! we need pics of the 2544 before you remove it's heart.
Now why would you want pics of that 2544? I've actually worked on it in the past, but the guy got a new mower and new I was interested in his so I guess I got dibs on it. I don't remember how many hours were on it but it wasn't so many that it scared me off. Body is in ok shape, but the deck is pretty much trash. That's why he got a new mower, the deck was having so many issues with belts, pulleys, alignment, etc that he got tired of messing with it.
Originally Posted by Dirty Steve View Post
If engine truly seized, that sucks big time. Congrats on the cheap 2544!
Thank you!
Ryan,
Overheated the engine by idling it too long? Not sure if serious or lew humor
But just in case, when it died the first time I had just finished a pass mowing and pulled up to the garage. When I started to reduce throttle so I could park and get off, it made a little grunting noise and died. I checked the gas thinking that may be it and it was low but I remember thinking it wasn't low enough that it should have died. I shrugged it off and topped the tank off. Then I tried to fire it back up and it grunted and shot some smoke out (too much choke? I'm giving the ol' girl the benefit of the doubt here...) but it eventually popped off and started. I left the deck off and the throttle about 1/3 or so and went inside for a few minutes. When I came back out, it was dead so I don't know if it made any noises or what, but that, as they say, is all she wrote.
-Ryan
Old 06-02-2017, 12:33 PM
On the to-do list
On a side note, and don't ask me how I got this thought going through my head, but the spacer that goes between the PTO and engine; is that just for belt alignment or is there another purpose to it?
-Ryan
Old 06-02-2017, 02:18 PM
Keeps the PTO the right distance from the engine block.
Old 06-02-2017, 02:21 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
On the to-do list
It is not for belt alignment. It spaces the stator coil far enough from the block and provides preload for the bearings.
Please, tell me you didn't forget to put it on?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-02-2017, 03:00 PM
I'm going back through my steps last night and I honestly can't remember. I'm 99% sure I did but I'll find out for sure soon enough
Edit: Even if I did, the thing had less less than 30 minutes of run time on it. I agree if I forgot it that that equals bad but I doubt it'd equal that bad that quick
-Ryan
Old 06-02-2017, 04:31 PM
CubDieselFan's Avatar
Old 06-02-2017, 05:21 PM
Originally Posted by CubDieselFan View Post
You and me both...tomorrow will be a big day for Cub guys everywhere!
-Ryan
