Leave the engine mount rails in there, and unbolt the engine from the rails. 2 bolts are easy to get to, the other two are in the axle C-channel...you'll need an offset 9/16" wrench. Then you can easily slide the engine forward an inch or two, or tip it up. It helps to have another person, because trying to get the engine lined up and the driveshaft in the ball, and the bolts through the rag joint all at the same time is a three-ring circus.
I use a tapered punch to align the engine after the driveshaft is where it belongs. Stick the punch into one of the rear holes where the engine mount rail mounts to the oil pan, and wiggle it around until the punch is in as far as you can get it. With the right size punch, it'll be lined up, and you can get the bolt in. Do the same thing to the other side and put that bolt in (loose) and then the front ones should line up. |
Sweet. I don't own and offset 9/16" wrench and I am doing this by myself. Would it be easier to remove the drive shaft and try to align it that way?
If you jack the front of the tractor up, you might be able to get in there with a socket and ratchet and/or socket and small breaker bar. Take off the front wheel on the opposite side that you're currently working on so you don't get your fingers smashed.
It's not impossible to get everything lined up if you're alone, but it isn't exactly easy. You should be able to tip the engine up a bit with one hand and guide the driveshaft into place with the other. I have done it myself a few times, it just takes longer. |
![]() Quote:
In your opinion, I can take out the driveshaft by removing the rag joints and then reinstall it the same way? Or on reinstallation to i remove that shaft from the 'yokes' and then install the yokes onto the engine and driveshaft and then reinstall the drive shaft pins? |
![]() Quote:
Since you're asking my opinion...... First thing I'd do is tip the motor forward again and get that shaft out of there. Second thing is to take the shaft completely apart. Clean and wire wheel all parts. Replace parts if they are worn. Paint all parts, I use Rust-Oleum High Heat 2000 paint, no primer. Pre heat parts with a heat gun or blow dryer, spray two coats. This particlar paint has no thickness build up and is long lasting and it does keep parts like the shaft from rusting. Wire wheel the pins and use anti-sieze when reinstalling. I will slide couplers and rags onto the shaft lose, insert the shaft into the bushing on the motor coupling adaptor, bring other end to the pump coupler and insert, now losely bolt the rags to the pump and motor coupler. Slide both shaft couplers to the rags and losely bolt those together, now install pins, tighten and adjust all rag bolts. Parts should look like this when installed. These pins have no anti-sieze on them at the time of the pic as this was only for fitting and I intended to remove and reinstall again. ![]() Note the paint finish, no build up to inhibit couplers. ![]() Don't forget your fan. I see no reason not to restore all parts prior to reinstalling them. Most of us will be working on our tractors again and again, might as well make it easy for the next go round. Scott |
![]() Quote:
Well put.....There are a few of us left! ![]()
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever! ![]() |
