Old 02-06-2017, 08:51 PM
Shaner Shaner is offline
Looks like a plow someone made for a wheel horse sleeve hitch
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 02-07-2017, 03:28 PM
Merk Merk is offline
Originally Posted by HydroCub149 View Post
ok so that looks good but what is the angle of that piece of steel/a brinly arch and how long is a regular brinly plow.
Back side of the standard to front bolt holding hitch on is 27 inches. There is an 15 degree angle built into the hitch so the plow will be close to straight up and down when your right side tires are in a furrow.
Here is anther Simplicity plow that I modified to accept a Brinly hitch:
I also have 2 extra Brinly frames that are up for sale.
Your moldboard-standard-frog should bolt up to a newer frame. The plow on the right in my earlier post is an older style frame with a newer moldboard-standard-frog on it.
The blue and yellow plow don't plug as easy as a Brinly frame plow does.
Project Uncle Dick
Cub Cadet 70
Old 02-07-2017, 04:55 PM
HydroCub149's Avatar
HydroCub149 HydroCub149 is offline
Thanks!
Cub Cadet 149 w/ sleeve hitch, rototiller, snowblade and deck, Cub Cadet 124 w/ sleeve hitch and deck Cub Cadet 1811 w/ deck and 18 big internationals 🇺🇸 🔧🐂
Brinley PP-100 plow
Cyclone Rake
Old 02-08-2017, 02:08 PM
no answer on the anvil???
