Have you considered rebuilding it yourself? Just have the shop bore cylinder if necessary, buy the parts and do it yourself. The Kohler's are pretty easy to work on even for someone new. A great learning experience. The Kohler manuals are available online. If you don't have the tools to measure properly, see if the shop will measure and tell you what is needed.
The shop I use usually charges $200 - $250 for bore, hone, cut valves and grind crank if required. The gasket kit including seals can be purchased for $30- $50 for aftermarket and more for Kohler. Hard to tell from your picture , but it does look like the front ( toward valves )is egg shaped which is common. |
I am the guy who will say if you've never done anything like it before, don't attempt it now. If your not a mechanic, don't try to be one.
saying to myself that I cannot do a certain thing, it is possible that I may end by really becoming incapable of doing it. On the contrary, if I have the belief that I can do it, I shall surely acquire the capacity to do it even if I may not have it at the beginning.
Mahatma Gandhi |
