View Poll Results: What would you do with this tractor
Down to the frame full restore stripping everything 10 40.00%
Touch up the getting rid of rust, but keept it original asihh as possible 15 60.00%
Voters: 25. You may not vote on this poll
Old 01-05-2017, 12:28 AM
johncub7172's Avatar
Seems like a lot of sound advice given thus far! I'll add, that if you are going for a restoration, be mindful of the good paint your tractor does have. On pieces, there is no need to strip down to bare metal, and then sand the bare metal. I'd just work the old paint down a bit, prime, and shoot!
Good luck!
Old 01-05-2017, 11:43 AM
farmall fred's Avatar
farmall fred farmall fred is offline
I have a 127 iin almost the exact same condition. I bought it quite a number of years ago with plans to stretch the frame and add a dump bed, but it starts,runs and drives so well I could not bring my self to cut it up. When I got it at a estate auction I was told it did not run. After buying it I put some fesh gas in it, opened the petcock and hooked up my jumpers and it started on the second turn. After warming it up I drove it up on my trailer. You should have seen the look on the face of the owners son, he was the one who told me it did not run. It had a receipt in the owners manual from a couple of years prior showing a new engine had been installed. Enough about my tractor. If it was mine and you want to use it as a worker I would get it running well, fix all leaks, change all fluids and hydro filter, fix mechanical issues and run it for a season. Then if you wish to do a restoration you will have a better idea of what it will really cost based on needed repairs etc. I would be temped to clean it up, paint the rims and give it a good wax and polish first. It is amazing what painting a set of wheels will do for its looks.
Old 01-05-2017, 12:17 PM
I'd like to point out that just a few weeks ago there was a big long thread about a lack of projects and here you all are trying to talk him out of one. I don't understand the phobia about working a restored tractor, my 108 has a nicer paint job than a new caddy but I have no issue working it to death, unless your driving through bushes and running it into stuff the paint wont get hurt.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-05-2017, 12:27 PM
mattoney mattoney is offline
I'm going to have to agree with the others above. Get the mechanicals in order, work with it a little bit to get a little bit of pay off and motivation to do more, then decide from there.
You'd be surprised how much those will clean up. It already looks a lot better than my 107 with three shades of yellow.
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 01-05-2017, 02:09 PM
I personally would fix what needs fixing, and use the tractor. Then after you have some seat time on it, then make the decision on if you want to make the commitment of a restoration.
Cause if you half ass it, and not do it right, it's by far better left as is.
What he said. Plus if you run it for a while you may find other things that need attention and save your self the issue of making a mess of a new paint job. I have an 1864 that I'm working on, I'll do the things that I know need work then run it for a season before making it pretty.
Old 01-05-2017, 04:50 PM
Do whatever you feel is necessary to enjoy your cub. Being that it is your first cub, I would probably just enjoy it as it and fix the mechanical stuff on it. In fact, if you want to, customize it a little by painting some jaws on the front grill, adding some "ears" to the hood and a "tail" out of the back maybe in the form of a plow that is painted up to look like a tiger tail. After all, they are cubs!!!
Old 01-05-2017, 06:12 PM
bnsfgp38 bnsfgp38 is offline
https://youtu.be/onMrq-lq5i8
Unloaded it today
Old 01-05-2017, 06:44 PM
twoton twoton is offline
Looks good, have fun with your project.
Old 01-05-2017, 08:44 PM
Dirty Steve's Avatar
The 127 looks great. Should be a fun project.
