Old 01-04-2017, 05:20 PM
gardenpest's Avatar
gardenpest gardenpest is offline
billy-o , both of my drives run east to west . the one i had good luck with is paved the one where heat started being a problem is gravel. (grrr i hate gravel). but i think the longer I ran it (about 45 mins ) the warmer the engine and the chute got .
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
Old 01-04-2017, 05:26 PM
mortten mortten is offline
Sorry. I was thinking quietline. Not enough sleep last night.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 01-04-2017, 05:47 PM
Good idea. You want to make sure you've got enough air flow around the engine regardless of outside air temperature.
Old 01-04-2017, 06:11 PM
I knew you knew the difference, I was trying not to smart you off too bad.
Old 01-11-2017, 08:10 AM
charlie105's Avatar
charlie105 charlie105 is offline
Flipping the grill made it better for me, but replacing the grill with a piece of aluminum sheet, bent at the top 3" to a 45deg. angle resolved my heat issues with the plow and qa36 thrower.
Old 01-11-2017, 08:42 AM
I've ran snowblowers on the front of Cubs for years. Used to clear business parking lots, including my own parking lot, plus about a dozen driveways. When it snowed I typically spent a 12-14 hour day on the tractor and sometimes half the next. I NEVER had any issues with engine heat affecting blower operation. If anything it kept the snow build up to a minimum and kept the chute free to turn. You guys that seem to think it's a hindrance are nuts. Besides, if it was an issue IH would have fixed it with a deflector or something. A hot chute doesn't cause it to plug. The snow type, and how fast you feed it does.
Old 01-11-2017, 10:32 AM
yeeter yeeter is offline
Originally Posted by gardenpest View Post
Now I can't wait for more snow.
While I understand the enthusiasm to try it out - I can indeed, wait...
Old 01-11-2017, 10:40 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Is your belt tight??? Seriously verify that it is.
Years ago my 36" on a 129 kept plugging up with the heavy snow we had. I was on an off the seat more than 100 times from 5 am till 730 am. The last time i unplugged it, i got a ride to the ER from a former teacher.
Fatigue, stress, and haste resuted in a broken index finger and the finger nails of my index and ring finger being torn off when my left hand broke through the snow packed chute into the rotating auger. I was later told by a witness that my left glove went up over the power lines.
I had left the seat to un plug the chute which was rotated far left, approaching it from the rear i didnt see the auger spinning. Having unplugged it many times i thought i disengaged the pto. I was wrong.
Dad ended up finishing my jobs. He said that he tightened the belt and never had another problem.
I have moved alot ... alot of snow with a qa36 on a 129 1450 and 1864. It throws snow 20 feet easy. Never once has the exhaust been an issue.
1- 1200 in pieces
1- 1864 in pieces
Old 01-12-2017, 06:50 PM
gardenpest's Avatar
[QUOTE=Rescue11;406172]Is your belt tight??? Seriously verify that it is.
checked belt on qa42 ,at most 3/8" side to side belt movement.but did notice s/g belt was loose so i tightened it.I had not checked this cub for rpm so I used a digital tach i got recently and it was set at 2900 rpm so i bumped it to a little under 3600. Turning the grill seemed to me to have helped ,I only had one clog last snow.But it was only 4 inches compared to 8 last time.However with a tightened s/g belt and 600 rpm increase my neighbor may be upset about the extra snow on his roof , we'll see .
