Old 12-30-2016, 07:13 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
second the washer fluid.Break the bead on the stem side of the rim put a 2x4 under the side with the stem put a big screwdriver in the bead to hold it open and pour away then pull the screwdriver out and inflate ,Done
Old 12-30-2016, 07:44 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Great idea Mike!
I never thought about doing it that way!
Around here in South GA we get away running straight water.... but it never freezes here more than a few days a year.. never long enough to freeze a tire.
Jay
Proud owner of the following:
Old 12-30-2016, 08:02 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
on my 982 is load and weights 300 lbs per side i haven't had any problems for over ten years. so i say load them. they probability don't wont to have to deal with little tires the small stem make it takes time.
Old 12-30-2016, 11:00 PM
Merk Merk is offline
I use an inner tube on any tire that is filled with fluid.
Project Uncle Dick
Cub Cadet 70
Old 12-30-2016, 11:58 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
that's exactly what i did. put 8 gallons in each of the tru powers. could have fit more but i wanted some room for air so it didn't ride to hard.
side note:
i dumped the aluminum rear in my 1772 and put in a IH cast iron rear. its been holding up the 550LB backhoe just fine.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-31-2016, 12:10 AM
I just filled the 10.50 True Powers on the 782 a week ago, and each tire took 7 1/2 gallons of washer fluid, and weighed 100# each. Broke the bead on the valve stem side, and dumped it in. Shot of air, and good to go.
Total cost. $ 19.35
Old 12-31-2016, 08:37 AM
Pretty much the same way I do it.
Old 12-31-2016, 10:53 AM
PSully PSully is offline
I like the idea of removable wheel weights myself, especially if your just mowing during the warm season. That way, you're not tearing up the lawn with the heavier weight.
Old 12-31-2016, 10:59 AM
Originally Posted by PSully View Post
I like the idea of removable weights myself, especially if your just mowing during the warm season. That way, you're not tearing up the lawn with the heavier weight.
Why does everyone think that extra weight tears up lawns? I run loaded tires and sometimes I leave the wheel weights too. It actually tears up the lawn LESS as the tires never slip. When there is no added weight on turf tires they spin so easily that you will "burn" areas with wheel slip. Loaded lugs are easier on the turf. I won't ever go back to non-loaded turfs. No traction, lots of slip.
Old 12-31-2016, 11:06 AM
jaynjeep's Avatar
Agreed... we run loaded and weighted ags on the lawn... no spinning when turning around or changing directions... You can't even tell the tires were on the lawn.. You would think they would destroy the lawn but they don't.. we leave them on year round
Jay
