Old 12-26-2016, 08:17 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
thanks Josh!
i really enjoy the building process.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-26-2016, 11:28 PM
Looks sweet to me....that doesn't seem that long of run...could always do like you said and use the copper as a reference and bend it out in 3/16" ss...for the pressure side anyways...I would think the copper would be OK, but I've never turboed anything...did run all SS brake lines on my truck though...make sure you get the right double flaring tool...cool build though...
Old 12-27-2016, 09:26 AM
mortten mortten is offline
The reason I mentioned it was an old Cub mechanic told me that was the reason they used steel line on the older Cub fuel lines with the rubber ferrules. They figured using copper would crack due to work hardening.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 12-27-2016, 11:34 AM
ken6x6's Avatar
got the exhaust all done. i recycled the exhaust from the first turbo, just cut off the old flange, added a section of pipe and welded the new flange on. now back to this oil drain
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-28-2016, 05:50 PM
ken6x6's Avatar
got the oil feed and drain installed. just waiting on the silicone couplers to get here, then i can make up the intake. ive been holding on to piece of 316 stainless tube for a while now. i think this will be perfect for plumbing the intake.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-28-2016, 05:58 PM
twoton twoton is offline
.... I, for one, think you're talented.
X2 on that! Keep the updates coming.
Old 12-28-2016, 06:58 PM
neilespo neilespo is offline
Nice work Ken! Keep building! I have a CASE 580CK diesel for you to turbo up.
Old 12-30-2016, 01:50 PM
ken6x6's Avatar
lets do it!!
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-30-2016, 01:52 PM
ken6x6's Avatar
the couplers i was waiting for just arrived!!!
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-30-2016, 06:16 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Looks good but you might need a brace on the exhaust they vibrate a lot been there done that.
