Good write-up there Yosemite Sam, thanks for taking the time to do that.
[B]Larry[/B] |
Thanks for all the ideas. The only thing I've had time to do so far is test the battery. It's about the same running as stopped, right there about 12 V. I have a needle gauge so I can't read decimals. It might be 12.5. But it doesn't go up noticeably when running. I didn't wait for it to warm up, I just ran it for 30 seconds or so and then tested.
I have replaced the battery (all too) regularly. At most every 2 years. This battery was new last year. The issue with cold starts and having to disconnect the battery between uses has been going on through several batteries, so perhaps the generator has been a smoldering issue all along. I'll see if I can find time this weekend to do some more testing.
Cub Cadet 2166 |
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
Here's another good reading link on the operation of the v/r.....
http://www.cubcadetman.com/cc/how-to...age-regulator/ |
OK, thank the snow gods they havent been angry this winter because I havent had to use the tractor in weeks and I'm just getting back to this.
I was thinking about this test when I stumbled across https://www.youtube.com/watch?v=bxTsANakLf8 I took the belt and wires off and used a jump starter pack per the video and according to this and what you've described below it appears my generator is a crispy critter. The starter spins fine when I apply power but doesnt slow when I move the power to the field post. However this sounds a little different from what you said (because you said run a wire from ground to field), so I thought I better check before deciding where to go next. Quote:
Cub Cadet 2166 |
Oh and...
I actually disconnected the starter wires weeks ago and now I can't remember which one goes to A and F... One wire is a very heavy gauge and one's a puny 12-14 ga, both were painted yellow by the previous owner just to confuse me I'm sure.
Cub Cadet 2166 |
Follow Yo Sams directions. Proper way is listed, briefly ground F terminal in that test not apply positive
That's what I thought. Thanks
So what is the guy in the video proving when he puts the pos on the F and it slows down? Anything?
Cub Cadet 2166 |
