Old 10-23-2016, 04:43 PM
ironman's Avatar
ironman ironman is offline
Are you guys sure that the OP don't mean the pivot arm the idler bearing is mounted on??
Yes, I believe that is what he meant, but J-Mech addressed that by suggesting he oil it. I can't recall where/when but I think I have seen grease fittings on those pivot bolts. Maybe they were home done, wouldn't be that hard to do.
Old 10-24-2016, 04:13 PM
i put grease fittings on my mule drives where the collar for the pulley bracket pivots over the round bar...super easy to do...right in front too..oil would be fine though...might have a pic somewhere but dont feel like digging for it... i like zerks though, and the easier to get to, the more often they get lubed...
Old 10-24-2016, 06:40 PM
I just got a new idler kit and spring today. Part #759-04324B, service kit.
It came with holes for zerts.
Old 10-24-2016, 07:50 PM
I believe that is what he is talking about. The later decks have a grease fitting. A lot of the older decks without a grease fitting I'd find rusted and frozen solid.
On the front on the mule drive idler, it's common to find the idler arm shaft worn from lack of lubrication. Again, the later mule drives have a grease fitting here and I find them not worn and in good condition.
Old 10-24-2016, 08:25 PM
twoton twoton is offline
http://www.onlycubcadets.net/forum/s...2&postcount=57
Old 10-24-2016, 10:19 PM
samiam44 samiam44 is offline
I'm talking about the pivot arm. My deck replacement pivot bolt was drilled for a zero and gets a shot every year or so.
Bot the spring loaded idler doesn't.
M
Old 10-24-2016, 10:22 PM
I'm going to do as mjcub did.. that's it. Exactly.
Old 11-02-2016, 07:06 AM
jsoluna's Avatar
jsoluna jsoluna is offline
My 44a had been sitting outside for about a decade. After I finally got the tensioner pivot bolt and arm separated (rust had bonded them together) I took the bolt to my machinist and had him drill a greaseway in it.
http://www.solunagarage.com
