Old 10-12-2016, 02:32 PM
kalebevans kalebevans is offline
For the most part I really like my 50" deck. It cuts evenly on the flat, looks nice when you're done, and you can really cover ground.
My biggest complaint was that the rental we were staying at had a really rough yard, so I was always scalping or leaving long spots because of all the dips. Hopefully my added wheels will help that; our new place doesn't have the smoothest lawn but it isn't nearly as rough. I'm planning on mowing the whole thing for the first time tomorrow, so we'll see how it does. I think the issue is that the deck sticks out about half a mile on the left, but the blades don't cut much further than the rear wheel sticks out on the right, so on any uneven surface that left side would poke up in the air or dig in and scalp. We'll see after tomorrow how my additions do...
My other complaint is that I wish the blades turned at a higher rpm. The clippings that come out are quite large and so they need to be cleaned up if I'm taking much off. Once I wear these blades out I'm hoping some Gator replacements will help chop the clippings more finely so it isn't as big of a deal. The JD LT180 from '04 I also use seems to turn the blades twice as fast and it doesn't seem like the clippings stick around as long. In comparison to other equipment from the era of my 169 I've used I think it's pretty comparable.
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original!
Old 10-12-2016, 05:20 PM
Well... THAT'S the rumor. But I'm doing everything wrong cause it all started with my 1330 lawn tractor with the 44" deck, ran it on it's wheels for 23 years, and only replaced the fronts twice.
Run my 50" on the 1650 starting with the wheels on the ground, then bring them up a nudge, let er rip, tatar chip. Same on my 44" under the 782, but it's got runners, so it's not right on the ground.
And as John said, the Haban's on the ground all the time... You talk about uneven terrain, I don't think it get's much worst than ours, and the wheels on the ground aren't going to make a uneven cut.
The deck is rigid, so it's not like the wheel can fall into a rabbit hole... The Haban's run the ground all the time, see any uneven cuts afterwards? Not on mine. My tractor, my way, your tractor, well, your way.
The Haban's have caster wheels. Those are different that gauge wheels. And no, a deck won't fall in a hole. But it sure will jump up over a mole tunnel or other large lump. And you went through 3 sets of wheels in 23 years? If you ran them up higher, you might have been able to keep the originals. To each his own, I suppose.
Old 10-13-2016, 12:58 AM
Yes, I know the Haban's are casters... And YES I know they are different...
Yes three sets in 23 years, at approximately 100 hrs. per year. I also don't have a well leveled lot to cut, it's acres of rough terrain.
The cut is much nicer looking with the wheels down than up, and as you said, "to each his own".
Old 10-13-2016, 10:48 AM
Regardless of wheel position... I don't think anything cuts as nice as these old decks. I had a brand new Husqvarna and the grass looked terrible after I was done. I think I would have gotten better results with a dull machete
Old 10-13-2016, 09:53 PM
I have owned two Supers with Haban decks, and about a half dozen Cub Cadet GT's with mowers,,
none cut as nicely as this 72" deck with four wheels that ride on the ground.
Everyone talks about big decks scalping, this one, in over a decade of use,,,
has NEVER scalped,,, EVER,,,
I think the reason is has never scalped is the twin center rollers.
They basically make the mower act like two 3 foot decks,,, NO scalping.
Old 10-14-2016, 09:08 AM
tasnyder83 tasnyder83 is offline
Thanks for all of the great information, didn't expect all the replies I have gotten on this.
Tab
Old 10-14-2016, 03:12 PM
Has anyone ever made a 'batwing' style mower for under one of these machines? I'm thinking a center blade that attaches to the machine, and then one blade off each side that all work together. Maybe 50-60" wide overall, and you could use a bagger with it... You'd have to have several gauge wheels, but it would conform to the curve of the ground like a gang of reel mowers. You wouldn't be able to pick the sides up much higher than your typical deck, but that'd be great for a hilly lawn. But incredibly expensive, I'm sure...
Seems like I may need a nap...
Old 10-15-2016, 10:40 PM
alsparl alsparl is offline
...actually yes, Cub Cadet Commercial retailed a Z-Wing Tank in the early 2000s. It was a 48" deck zero turn. We had one at the dealership as a demo...and to be honest, I loved the machine, especially considering I have 3 walk-in gates in my fenced yard and it went right through with the wings folded up. I am not sure if they ever took off though.
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 10-17-2016, 03:36 PM
That's pretty slick. My 50" deck is 60" overall, so to avoid scuffing I need a 5.5-6' trailer and gates. I don't yet have a trailer, and have a lead on a cheap 4' wide one, but having to take the deck off each time might not be worth the low price. Now to daydream about getting a used Z-Wing deck and fabbing it up for my machine...
