Old 10-13-2016, 12:38 PM
Steve149's Avatar
Steve149 Steve149 is offline
yes both of mine are too...my neighbor said that they should be on the inside! All the pictures I have looked at the hinge is under it sooo.
Old 10-13-2016, 12:59 PM
The hinge should be between the headlight panel and the front casting.
If you look at the under side of the hood extension there is a provision for the hinge to fit into.
Old 10-13-2016, 01:15 PM
Steve149's Avatar
I saw that! The hinge that is on my 108 must have been replaced by the PO at some point cause it is about 3/4" above the nose casting when in place...I will have to trim it up a bit.
Old 10-14-2016, 08:12 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by Steve149 View Post
Ok while working on this hood issue...I have come across a question that I have gotten mixed answers on. When mounting the hood to the hinge should the hinge go between the grill panel and the nose casting or on the inside of the grill panel? Most of the ones that I have seen the hinge was between the panel and the nose the hinge looked trimmed so it didn't show...which is the right way???
Not sure I understand the question, but if it helps here is a pic of my 149....
Old 10-14-2016, 10:18 AM
Steve149's Avatar
looking at your picture if my eyes aren't playing tricks on me since I have been up since 4am...your hinge is mounted on the inside of the headlight panel. I looked again at mine last evening and it is between the panel and the nose casting. As Yosemite Sam said there is a notch in the casting for the hinge. The PO of this 108 replaced the hinge at some point and it wasn't drilled right so when I put it back together I wasn't sure which was the correct way...the way mine is mounted now with a different hinge you can see the top part of the hinge when looking at the front of the tractor. I will have to trim it off some.
Ironman that is one nice looking 149 ya got there!!!!
Old 10-14-2016, 04:47 PM
ironman's Avatar
I now think I understand what you are saying. Unfortunatly the tractor is at my other place, 60 miles away or I would go out and have a looksee for you. But in any event, thanks tor the compliment.
