Thread Tools
Display Modes
Yes but we don't, the chunks of paint that come off like to clog the tip when it's reused
you should put a sifter thingy on the bottom of the cabinet to catch the debris.
I'm Mr. Small time compared to you experts, but I like the Black Diamond. I blast on the cement driveway, then sweep it up and screen it back into the blaster. Reuse it three times, then in becomes part of the gravel driveway.
To the OP. I would be causes blasting around the differential, stuff get's in everywhere, and hard to get it all back out. I do not blast anything that will have oil in it. Diff, or engine... ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
we use glass beads in the cabinet, the silica sand gets used for the big stiff. we have a 12x16 building we blast all the tractor parts in, the blaster holds 100lbs and is powered by two big screw compressors. we've tried sifting it but its so time consuming that its not economical.
Hey Zippy brought up a good point, how do you clean/strip the rearend and hydro housings? I was leary about having them blasted due to the openings and having the abrasive remianing inside.
Matt
Not New to the cub world, but just getting started. ![]() Current: XT3 GSX - 60" fabricated deck - spreader - 12cf steel cart - sun shade - 46" front blade IH 129 - 44" deck - ported pump (work in progress) (on radar) 1572 - 60" Haban fabricated Deck - other options unknown IH Tiller for the 129 |
I Use Black Diamond On Everything But The Rear axle. Use soda for that.
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
![]() Quote:
