Old 08-20-2016, 10:35 AM
BillZ BillZ is offline
Here are some better pics, now that I can work in the light of day and have the hood and grill off. Looks like the wear button is completely worn and the actual lever was pressing on the center of the clutch.
Also, according to the video I saw, I don't think the set screw holes aren't lined up properly.
Since I'm this far, I might as well remove the the whole thing and take a look at it. So far I know I definitely need a new wear button. Other thoughts?
Old 08-20-2016, 11:41 AM
Well, that's what's left of the wear button...
Old 08-20-2016, 11:43 AM
This is the part I need, correct?
http://www.pattonacres.com/cub-cadet...ces-473483-r1/
Old 08-20-2016, 11:46 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
Personally i would leave it alone aside from checking the bearing. Without the tool that comes with the rebuild kit it can be difficult to set it up. You will also need a very thin 7/16 wrench. The set screws only line up when you disengage the clutch and turn it. I don't mean to discourage you but if the bearing feels good I wouldn't worry about it. Just my
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 08-20-2016, 11:48 AM
Mr.Goffena's Avatar
Originally Posted by BillZ View Post
That is it. I didn't like the brass one I got. I went back to the original. I dont know how they last for others but I didn't like mine.
107 with rear lift
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
Old 08-20-2016, 11:53 AM
Thanks, I think the clutch is ok otherwise. I'm inclined to replace the button and be done with it, since the clutch did work ok while the button continued in its existence.
Old 08-20-2016, 12:05 PM
I agree, I'd leave the clutch alone and just get a new wear button.
Pap's 100
Restored 108
1211 Dual Stick
1050
