You don't want to do this if the belt is on it.
the bearing might be on the crank too far and when you release the clutch the spring will hit the end of the crank
Some other thoughts comes to mind........Bearing could be frozen/seized. Or bearing might not be "locked" on crank (What Dale mentions brings this to mind!)
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Bearing is new and locked flush with the crank. Going to pull it in the morning
Are you missing the snap ring on the clutch housing?
If I remember correctly the snap ring was there.
Here's a couple of pics. The snap ring is there. Double checking with the gauge in better light it looks like I've got the bolts a little too tight.
Second pic
From the front it does look a little tight, but from the back it looks like just the one (closest to the camera) is too tight.
How about a picture of the end of the crank?
Here's a picture of the crank. The bearing is about 1/8" past being flush with the end. That's not how I remember leaving it. Maybe I didn't lock it down tight enough.
