Closed Thread
Old 07-14-2016, 08:37 PM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
Looks pretty cool! Keep us updated on how it performs.
Old 07-16-2016, 07:00 PM
52'F-3 52'F-3 is offline
Originally Posted by twoton View Post
Looks good there 52'F-3, keep the pictures comin'. And welcome to OCC.
thanks for replies, I also like threads with lots of pictures.
got a pulley mounted on the driveshaft; plan to drive this hydraulic pump. still a lot of work get it going.... but it's a start. it will power the hydraulic hoist, steering and snow plow if all goes as planned. got the hydraulic steering setup of Ebay, seller said it came off an 1864.
Old 07-17-2016, 06:46 AM
That EZ-GO golf cart axle isn't as heavy as what the tractor has on it. Only difference is it has hub style wheels.
the axle "beam" is heavier for sure. but everything else has got to be stronger. with the center axle pivot gone and wider width, I think it will be more stable carrying a load. each tire payload is 975 lbs.
still no steering yet....
Old 07-17-2016, 10:29 AM
Looks nice! Please keep the pics coming.
Old 07-19-2016, 06:33 PM
mounted steering cylinder in non-standard location, (i'll have to modify snow plow mounting later)
Also had some difficulty, but got orbital valve and steering shaft in it's mounting location. still need to make a couple mounting brackets and modify steering column housing/bushing.
Old 07-19-2016, 09:01 PM
SO...... how do you plan to keep all 4 tires on the ground with no pivot on the front axle??
Old 07-20-2016, 05:26 AM
it won't be a problem, but thanks for your concern.
overall picture;
Old 07-22-2016, 05:01 AM
Dirty Steve's Avatar
Is it just me or is there a flying rat rod trying to escape your shop?. You have a very impressive work space. That car lift is awesome! AND the Cub lift is pretty slick. Thanks for the pictures.
Old 07-22-2016, 08:20 AM
overall picture;
Looks like an accident waiting to happen to me.
Old 07-22-2016, 07:38 PM
overall picture;
I like the idea of the solid front axle. I have no idea how much weight and how high you want to carry it but whatever, it will make the tractor more stable than if you had a pivot.
Closed Thread
