Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 12-02-2016, 04:09 PM
Didn't Frank F3 rebuild his own?
I think he rebuilt it....not built it.
Old 05-15-2017, 01:09 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Yes I did rebuild it. Here is a link to that thread. Maybe there could be a better way to locate the thread if it is needed....
http://www.onlycubcadets.net/forum/s...ad.php?t=36410
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-09-2017, 10:26 AM
WEL58's Avatar
WEL58 WEL58 is offline
Angry Kumar D600 Water Pump
Well last night cutting the grass, started to hear a squeal. Cut off PTO still hearing the noise. Stop the engine and found the Kumar water pump installed last summer has seized.
I have the old water pump already to reassemble but have not been able to source the water pump bearing yet. PartsTree no longer have bearing in stock.
Any other sources for water pump bearings?
McMaster has a few but have not sit down to compare the dimensions.
Bob G.
Old 09-09-2017, 10:46 AM
Here ya go my friend.
Messick's
http://www.messicks.com/search?q=15852-73050
http://www.messicks.com/part/15852-7...aring-ball-rad
or
http://www.messicks.com/search?q=15841-73050
http://www.messicks.com/part/15841-7...aring-ball-rad
Yacht Supply
http://www.yachtsupplydepot.com/engi...rod_39727.html
http://www.yachtsupplydepot.com/engi...rod_41563.html
or
http://www.yachtsupplydepot.com/engi...rod_44297.html
http://www.yachtsupplydepot.com/engi...rod_38817.html
****As always with my posts, double check the part numbers
Old 09-10-2017, 05:03 PM
WEL58's Avatar
Thank Oak for the two sources.
Duh.. Forgot the real Kubota part number was minus the 'KB' prefix that Cub Cadet uses.
Googling the real Kubota numbers return many more sources...
Placed an order with Kubuta Parts Depot' https://parts.mbtractor.com since listed items in stock.
Order all four items to compare what are the differences....
[1] 15841-73050 - SEAL, ASY MECHANICAL $11.48
[1] 15841-73550 - BEARING BALL RADIAL12/26 *** $53.35
[1] 15852-73550 - BEARING BALL RADIAL12/26 $26.68
[1] 15852-73050 - SEAL,MECHANICAL ASSY $15.50
Subtotal: $107.01
At checkout, list as non- stock 3-5 days shipping. There policy says non-stock orders will be drop shipped. Will see how this goes.
Have used Messick and Yacht Supply before. I the past Messick orders ship to them and then reshipped to me. Unfortunately Yacht Supply is shutdown due Irma and best wishes for them.
Will post when get the parts.
Thanks to everyone,
Bob G.
Old 07-29-2024, 04:36 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Originally Posted by WEL58 View Post
. The bearing seized up in middle of cutting grass.
Bob G.
Same just happened to me. Hope to get the new pump on tomorrow
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
