Old 07-01-2016, 09:20 PM
Originally Posted by RV-ERR View Post
UPDATE!!!!! I pulled the creeper off this am as I move it forward the grease flowed and I could here chunkies falling into the pan,that was an oh crap moment but it was just the spirol pin in 4 pieces. Now the next question is----can I swap the creeper and clutch drive shaft assy to my 108 and the clutch and drive shaft out of the 108 to the 1200,all reply's have been welcome. CURT
I just checked my cut list for driveshafts and the difference in length between the two is 1/32" ( 108 is the longer one)
Old 07-01-2016, 09:40 PM
then id say the answer is yes.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-01-2016, 10:11 PM
The part # is different between the two,I do believe the holes are in a different location.
I took a pic for you...
Old 07-01-2016, 10:35 PM
the only difference appears to be the hole closest to the trans due to the 1200 having a different coupler than the 108, if the driveshafts were switched coupler and all i dont see why it wouldn't work.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-01-2016, 10:39 PM
the 1200 uses the same coupler as a 108,so there goes that idea.
Old 07-01-2016, 10:43 PM
havent been around to many 1200s but the ones i have seen had a setup with rag joints like a hydro, my 108 and all the other wf gd i own have a solid metal coupler.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-01-2016, 11:01 PM
Tim, you have a point there.
Old 07-01-2016, 11:04 PM
well that's 1 for me and about 100 for you so your still winning.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-01-2016, 11:15 PM
The only other issue I can see is why change the driveshafts?
Old 07-01-2016, 11:26 PM
I agree, why not just replace the 1200 creeper pin and move on.
Will the Wide Frame bearing fork work in the QL tractor?
How did the pin get into 4 pieces?
