Old 06-27-2016, 10:40 PM
csgillaspy csgillaspy is offline
Guess that makes sense, never thought it would be aluminum.
I have a dial caliper, only thing I really have to measure the hole
Old 06-27-2016, 10:44 PM
That will work well. Take your time and see what size the hole is. Then we can pick a thread size to retap it.
Measure with the tips just in a little bit and then farther in. That will let you know if the hole is tapered ( from being a NPT pipe size )
Old 06-27-2016, 11:01 PM
Ok let me check
Old 06-27-2016, 11:15 PM
.650 is what it is at the bottom, middle and top of the pan hole.
Here are some pics
Old 06-27-2016, 11:21 PM
that pan should have a straight thread and the plug will have a lip on it with a rubber seal.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-27-2016, 11:30 PM
You have a pic of the appropriate plug cause mine definitely isn't correct
Old 06-27-2016, 11:33 PM
bocephus1991's Avatar
Boy that thing is smooth! Not a thread left in it! Good luck on tapping it!
Brian
Old 06-27-2016, 11:38 PM
Change the oil pan with correct plug already in it...
http://www.ebay.com/itm/Cub-Cadet-DE...gAAOSwepJXXxtq
Old 06-28-2016, 12:01 AM
Yea I might just have to replace it to make it right
Old 06-28-2016, 07:03 PM
What would be a little bit bigger than 3/8 npt
