Old 07-01-2016, 05:27 PM
Unseenthings Unseenthings is offline
Looks like 1 wire to me...
How does one lock the crank to remove the center bolt?
That which is seen is temporary, that which is unseen is eternal, therefore, focus on the unseen things.
I own a 2084 Super Cub
Old 07-01-2016, 05:54 PM
use an impact gun or remove the tunnel cover and and use a pipe wrench on the drive shaft to keep it from turning,I like using the after mentioned as it does not mar the driveshaft up.
Old 07-01-2016, 07:25 PM
Thanks for the tips, it is off now and an xtreme replacement ordered.
hopefully this was the problem.
Old 07-01-2016, 07:46 PM
Looks like you got your use out of that one.
Old 07-01-2016, 11:26 PM
I've seen worse and they work properly.
An ohm reading would confirm good or bad/shorted to ground.
Old 07-01-2016, 11:34 PM
RedOnes's Avatar
RedOnes RedOnes is offline
Looks like a picture taken by the Hubble space telescope of a black hole ..
Frank
IH 982 , 3 point
CCC 782
