Coinman66, check out post #16 in the thread. "Bad vibration on 1450".
http://www.onlycubcadets.net/forum/s...7&postcount=16 |
![]() Quote:
Aaaah ok. So to take PTO off, just remove the big bolt in the center where the pulley is? Or do I have to take off the 4 bolts with the springs on them to check out that bearing? Thanks |
Download the factory service manual and the owners manuals available here I believe in the Manuals section.
Removal and adjustment of the Q/L PTO clutch is covered in detail. Are you sure you have power to the PTO? Are you sure you have power to the switch? Check the fuse on the tower, left side You may just have a broken wire or a blown fuse. |
![]() Quote:
coinman66,
PTO switch (part # 925-3022/725-3022) Air gap adjustment; http://www.onlycubcadets.net/forum/s...109#post336109 good luck,... ![]() |
