Old 06-12-2016, 11:21 AM
ambrola's Avatar
ambrola ambrola is offline
If it runs and don't smoke or knock, I'm bringing her home. I am also takeing my compression checker and will check that also. Like I said, I have always bought old Gravelys, and this will be my first Cub so I don't know much about them. What is the rear lift used for?
Old 06-12-2016, 11:26 AM
leave the compression tester at home, these engines have a compression release to help them start so the reading wont be accurate at all.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-12-2016, 12:27 PM
ambrola's Avatar
Thanks Tim.
Old 06-12-2016, 05:52 PM
The 3 point hitch is used for lifting many object, like a tiller, a cultivator, a disc, a rear blade, etc. Look carefully, that also has a bracket with a bolt in it above the driver's left rear tire....up on the frame. That bracket is for a spring assist, which makes implements seem like they are about 1/3 of their weight. Someone had several "optional extras" on that cub. That is a good thing!!
Old 06-12-2016, 10:21 PM
To make that rear hitch funtion you need the lower bracket that goes behind the hitch, it's on the left of the picture.
"What can you use with it"? Moldboard plow, rear blade, tiller, rake, pretty much all of the attachments for the rear. The possibilities are endless.
Old 06-13-2016, 07:45 AM
ambrola's Avatar
Are those the parts I need Zippy? #6 I think?
Old 06-13-2016, 11:15 PM
Yes sir, that be it.
And three longer bolts.
Oh, and by the way that hitch is on upside down.
Old 06-13-2016, 11:27 PM
#8 is not needed. ...
Up to 534 and counting...
Old 06-13-2016, 11:30 PM
i have a spare #6 around here somewhere, pm me if your interested.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-14-2016, 06:28 PM
TheSaturnV's Avatar
ambrola,
The hitch (#7) is upside down on your purchase candidate, as someone pointed out. Refer to your drawing for the correct way, and the bottom 3 bolts have to be longer to be able to reach through #6 and 7.
